OpenTelemetry Datasource for Grafana
Was hoping if to get some direction if there’s any Datasource which is available within Grafana ( I could not come accross any so far) which can be used to Display OpenTelemetry(on GKE) Traces to Grafana ?
Regards,
Hi @Rohan,
Though I am not 100% sure but I believe Tempo is the one you are looking for.
Found this article as it uses Opentelementry for K8s.
I hope this is what you are looking for.
Thanks @usman.ahmad ,
While browsing i came accross this project - Do you believe this could be a Datasource used within Grafana? have any insights on this initiative?
OpenTelemetry | Grafana Labs.
I wonder if you can leverage this plugin
