I’m new here, wanted to create a text(html) panel in the top to show where the user is, the node ID and it’s name.
[ Using opennms ]
this is the var which filter the nodes: nodeFilter(nodeLabel LIKE “$group%”)
Everything working properly, the whole dashboard, but i just didn’t find any way to print the node name, what var or script should I use.
Sorry if looks stupid, I really stuck in this simple thing.
Thanks, Lucas
