I tried to install grafana in Windows plattform, but I didn’t get sucessfull to start the grafana windows service using nssm tool. I still don’t know how is the root cause of this problem…In this way, I’m trying, for this moment, to use The Host Grafana and it works well.
I preferred to use OpenHistorian because its better than openPDC, openhistorian works with version 2.0 and openPDC works with version 1.0.
Please, how can I associate the openhistorian 2.0 version with Host Grafana? I checked that openhistorian 1.0 version is possible and default, but I don’t know how associate the .dll file of version 2.0, and as I’m using Host Grafana, I don’t have the files installed on my machine, and I cannot copy the .dll file (version 2) to my machine.
Hi Torkel, yes I did, but only version 1.0 is available. What’s happening is that with version 1.0 I cannot use the software openHistorian. For that, I need install plug-in version 2.0
Please, how to agregate version 2.0 inside grafana?
Grafana is installed in openHistorian but version 7. For some plugins I need 9 or 10. I fon’t know how to upgrade it.
The other solution is to install Grafana on my computer and install openHistorian plugin as data source which I did. But when I want to set openHistorian as data sorce by setting URL input localhost:8180/api/grafana Grafana report error - bad gateway.
