Open Weather Map show NA on one panel
I am using the latest grafana image in a TIG stack on linux
I am trying to get one weather panel on grafana dashboard working. Keeps showing NA
I looked at the json file but couldn’t see anything. I am very very new at this lol
This is the dadhboard I am using Open weather map
I checked and made sure I am using the right api key.
I checked the data source and it’s the correct one.
I inspected the data under the panel and it’s pulling the conditions but they are not showing up on the dashboard.
link to data inspector
this is the collector info I am using
> Blockquote
[[inputs.openweathermap]]
  app_id = "xxxxxxxxxxxxxxxxxxxxxxx"
  city_id = ["#######"]
  interval = "10m"
bump. anybody care to help please?
