I’m configuring a grafana dashboard variable using custom variable type and I’m separating the values based on comma like this:
The variable returns correct value. However, the sql panels weren’t working properly. To troubleshoot, I used the variable query in panel and this is what I found
Troubleshooting steps:
- I changed custom variable to query type. Still only 1 value shows in query.
- I removed the space next to ‘Option’ to see if that’s causing the issue. But the issue continue to exist.
- Sometimes quoting the variable in single quotes works and some other time, it doesn’t
select concat(name, '--', id) from boards where name IN ('${board_name}')
select concat(name, '--', id) from boards where name IN (${board_name})
Any solution is appreciated.
