Okta authentication with group and user attribute condition
10.4
okta authentication, group-based and attribute-based role
role_attribute_path: “(contains(groups[*], ‘Dept_X’) && data.attribute1 == ‘true’) && ‘GrafanaAdmin’ || ‘None’”
  • What happened?
I get the None condition
This is where things get interesting. I’m trying to do a combination of group membership and a user-level attribute equaling a value as the conditional decision. The idea is that we are doing using a single group, say for a bunch of devs, but we only want them to have access when a given attribute matches a value - eg more than simple group membership.
I’ve experimented with the stanza on jmespath.org - here is the query and (dummy) data for validation:
query: (contains(groups[*], 'Dept_X') && attributes.key1 == 'true') && 'GrafanaAdmin' || 'None'
data block:
  "groups": [
    "abc",
    "Dept_X"
  "attributes": {
    "attribute1": "x",
    "attribute2": "val2"
If you change the value of attribute1 from “x” to “true” the result will change to GrafanaAdmin like it should
The part I am missing is how to access the custom user attribute key in the spath condition. I have set the log level of grafana to debug and I see (sorry, doctored a bit, reformatted for ease of reading)
logger=oauth.okta t=2025-03-27T18:33:24.969204252Z level=debug msg="Received user info response"
raw_json="{
  "sub":"xxxx",
  "name":"xxxx",
  "locale":"en_US",
  "email":"xxxx",
  "preferred_username":"xxxx",
  "given_name":"xxx",
  "family_name":"xxx",
  "zoneinfo":"AmericagLos_Angeles",
  "updated_at":1234,
  "email_verified":true,
  "groups":[
    "Everyone",
    (... snip )
    "Dept_X"
  data="unsupported value type"
I’m hoping the attributes are buried somewhere in data. I can’t see the value so its hard to know what to key off of.
If I take the attribute bit out of the spath authentication works and I get the appropriate role so this is not an issue with the grafana / okta configuration.
This is a weird userinfo response. Are you sure that data key is outside? Could you provide real example, pls?
All I did was remove the \ and add some new lines. That data=“unsupported value type” is how it was in the original log. Here is a redacted-only version:
logger=oauth.okta t=2025-03-28T14:02:20.277937117Z level=debug msg="Received user info response" raw_json="{\"sub\":\"xxx\",\"name\":\"xxxx\",\"locale\":\"en_US\",\"email\":\"xxxx\",\"preferred_username\":\"xxxxx\",\"given_name\":\"xxx\",\"family_name\":\"xxxx\",\"zoneinfo\":\"America/Los_Angeles\",\"updated_at\":123,\"email_verified\":true,\"groups\":[\"Everyone\",\"xxxx\",\"xxxxx\",\"xxxxx\",\"xxxx\",\"xxxxx\",\"Dept_X\"]}" data="unsupported value type"
OK, so userinfo is:
    "sub": "xxx",
    "name": "xxxx",
    "locale": "en_US",
    "email": "xxxx",
    "preferred_username": "xxxxx",
    "given_name": "xxx",
    "family_name": "xxxx",
    "zoneinfo": "America/Los_Angeles",
    "updated_at": 123,
    "email_verified": true,
    "groups": [
        "Everyone",
        "xxxx",
        "xxxxx",
        "xxxxx",
        "xxxx",
        "xxxxx",
        "Dept_X"
There is no attributes.key1.
Looking in the okta_oauth.go#L36 we can see there is an attributes element to the json which seems like what I would want. I’m trying that blind right now ( its not working either ;( )
If I’m understanding okta_oauth.go#L146-L152 if the attributes are being pulled from okta they are not preserved for the Userinfo - only group membership
Well there is no attributes - its more than just missing key1. The attributes themselves do not appear to be available
Yeah, your IDP didn’t add attributes to the userinfo response, so Grafana can’t use them. Check your IDP doc how to add that.
Do you know if the attributes would be under attributes or data by chance? Has this been done before?
I don’t understand. You need userinfo:
    "sub": "xxx",
    "name": "xxxx",
    "locale": "en_US",
    "email": "xxxx",
    "updated_at": 123,
    "groups": [
        "Everyone",
        "xxxx",
        "xxxxx",
        "xxxxx",
        "xxxx",
        "xxxxx",
        "Dept_X"
   "attributes": {
     "key1": "true"
and then you can use jmespath “attributes.key1 == 'true'
My expectation was that the attribute would show up as your example is written - that I would have an attributes dict with key/val pairs that I can condition off of as your response is suggesting.
I don’t have access to the okta configuration - it’s done by a different person. I’ve asked to double-check that the attribute is set and the key/val are what I expect.
I had expected that the log level being debug I would have seen that attributes element, and I don’t. So either grafana doesn’t support it in the okta configuration/provider or its not configured properly.
I’m asking if you know of others doing what I’m trying to do with attributes.
IMHO key/value attribute is not a standard (but that depends on your IDP team preferences and your IDP options). I would probably rather use roles (so authorization will be based on groups AND roles) - that’s sounds better to me, than attributes.
