Okta integration authentication only
  • Grafana 11.5.2, Docker Linux
    We want to Integrate Grafana with OKTA. But we don’t want to map group or role from OKTA.
    We want OKTA to authenticate users , but we want Grafana to perform authorization based on user passed by OKTA.
    We want to achieve it by mapping ADS group to a team.
  • What happened?
When I am mapping a ADS group to team, users are not getting proper access.
    We want users to assign persmission a sper team and its role configured in Grafana.
    No
  • Yes
    Configure Okta OIDC authentication | Grafana documentation
Technically, it’s still authorization (not only authentication) - use role mapping and map role based on particular user attribute, e.g. only jan@corp.com email will be admin and others will be viewer only (just example, not copy&paste solution, customize&improve it for you IDP response/user structure):
role_attribute_path = "contains(['jan@corp.com'], email) && 'Admin' || 'Viewer'"
You can use any available function in that jmespath to implement mapping business logic based on your need.
