OAuth just not working
Hi All,
I’ve been trying to enable OAuth integration with Okta but it just isn’t happening. I’m using the latest docker, Grafana v6.0.2 (3f4c2e7).
Everything is set up per the instructions at both ends. The default login form is behaving as normal (doesn’t accept okta logins). Both login/Okta and login/generic_oauth return 404.
Grafana logs show nothing except the 404 and Okta logs show nothing.
Sorry problem something dumb but I’m stuck so appreciate any help.
Thanks Crunchy
fixed it! was a typo type problem
