Grafana Cloud Okta Integration
Hey
I’m trying to get Okta OAuth working with my Grafana Cloud instance. I seen some previous topic chat that it was only available on certain plans, however I think the plan structure has since changed.
How do I go about getting access to the settings files to set up OAuth?
Also, what is the support address for the “8x5 Email Support”?
Theres nothing obvious to me when I am logged in.
Thanks
Martin
I have the same question, I am on the standard plan, which clearly indicates both OAuth support and an email contact, but neither can be found in either grafana.com nor (instance).grafana.net. I want to use Auth0. Thanks!
