Hi Grafana Community,
I’m experiencing an OAuth auto login bug when using a sub path in Grafana.
This issue causes URLs like /grafana/grafana/... (double /grafana/) to appear instead of the expected /grafana/....
Environment
Grafana Version: 11.5.7 (also occurred in 11.6.3)
Deployment: No reverse proxy (direct access)
root_url:
https://aaa.domain.com/grafana/ -
serve_from_sub_path:
true -
oauth_auto_login:
true
Issue
When auto-login via OAuth is enabled,
the Referer and some internal redirects/links are generated as /grafana/grafana/...
instead of /grafana/....
For example:
Referer: https://aaa.domain.com/grafana/grafana/d/xxxx/...
This causes dashboard access and plugin API requests to break.
What I Tried
Disabling/enabling
oauth_auto_login– bug only appears when enabled. -
Checking
root_urlandserve_from_sub_pathvalues. -
No reverse proxy (accessing Grafana directly).
Removing plugins (such as grafana-lokiexplore-app) – issue persists.
Restarting Grafana after config changes.
Expected Behavior
- All URLs should be generated as
/grafana/...,
not/grafana/grafana/....
Question
Is this a known bug in recent versions?
Are there any workarounds or settings to avoid this double sub path issue?
Any recommended configuration for OAuth auto login with sub path?
Any help or suggestions would be greatly appreciated!
Thank you.
