Number of Dashboards on my Grafana Instance
Grafana V9.2.4 and Linux OS
We have to find the count of dashboards for all the users
Preferable way is throug HTTP API Calls
  • What happened?
Hi @nandanchapa,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
Yes, you can monitor Grafana itself and view its internal metrics. You can follow this documentation link and also there seems to be a pre-configured Dashboard which you can import to view them.
I hope this helps.
That dashboard uses Graphite so it no longer works, and anyway it does not seem to include such a statistic. I cannot find a metric for this from grafana.
For enterprise users, grafana insights might help but I’ve not tried.
My solution is to export all dashboards with a tool like grafana dash-n-grab and then count the files locally. As a last resort you can query the grafana database.
