Javascript function to calculate total panel created in Grafana
Hi all,
I would like to create a dashboard which can calculate the total list of panels in Grafana by using HTML & Javascript as per example below:
I would like to know is it possible to calculate the total panel which I have created in Grafana?
Thanks in advance for your help.
Regards,
Farah
Use dashboard API and parse&count panels of all dashboards - similar example https://github.com/monitoringartist/grafana-utils. Dashboard (not panel) contains user relations, so “total panel which I have created” will be tricky. However you can parse dashboard versions and create panel ownership relation based on that.
Hi, thank you so much for your help!
