9.3.1 -
I want to use relative time in a query -
With this extra line in the query: WHERE Date BETWEEN ‘now/M’ AND ‘now’
And: With this extra line in the query: WHERE Date BETWEEN ‘now-30d’ AND ‘now’ -
What happened?
Nothing, I get no data -
I hoped I can select the data from this month with “Beetween”
what is your datasource? sql, influxdb, mysql?
I use a sqlite plugin
