What Grafana version and what operating system are you using? v8.5.0, Ubuntu
What are you trying to achieve? Build alerts using the new Unified Alerting
- Add alert rule and labels to it. Ex = service=celery
- Add Contact Point to Slack with webhook. Test works fine.
- Create a Notification Policy. Set matching rule to service="celery"
What happened? Alert not received on Slack.
What did you expect to happen? Alert to be received on Slack
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No
Did you follow any online instructions? If so, what is the URL? Notification policies | Grafana documentation
we might need more info if we are to help you with this issue… ![]()
