Grafana v9.5.1 (bc353e4b2d) -
More than one top level policy -
Using the API -
What happened?
Even if I change the receiver name here, it just overwrite what I already have (expected since it’s a PUT) -
I want more top level policies and I’m not able to do it also using the UI. -
Manage notification policies | Grafana documentation
Add new nested policy
- In the left-side menu, click Alerts & IRM and then Alerting.
- Click Notification policies.
- From the Choose Alertmanager dropdown, select an Alertmanager. By default, the Grafana Alertmanager is selected.
- To add a top level specific policy, go to the Specific routing section and click + New specific policy.
I don’t see any specific routing section in the UI
I’m stuck on one top level policy (with nested ones)
