Not the right decimal notation in the exported CSV file
Hello, I am trying to export data from the Graph Panel. However, where choosing Unit->Misc->Locale Format shows me the right decimal notation format for european users (using comma instead of a dot), the exported CSV file uses a dot instead, even though I’m using a french version of Windows and using Chrome Browser with its locale config set to fr-FR when it comes to language.
Is it possible to have the data exported with the appropriate decimal notation or not?
Hey, I’m currently stuck with the same problem. Have you found any solution for it?
Just in case anyone will have the same problem: It wasn’t a Grafana but a Excel problem for me, i had to change the separating delimeter from . to ,
