Hey Grafana Community!
I am hoping to export German language from a Table visualization.
Here’s an example:
^ In the Dashboard everything looks great
^ Result after opening the exported Excel format data.
What are some good fixes for this?
Here’s an example:
Hey, nice to hear from you again.
Info from Link: using the ‘Export for Excel option’ in Grafana adds the sep=, line at the top, which then breaks the UTF-8 interpretation specified by the BOM (apparently that is a bug in Excel itself)…
So a potential workaround is:
Instruct the User through the Dashboard NOT to use the Excel option, and show them how to open the file through Excel’s Import Wizard to manually specify the comma as the delimiter.
Then they get the UTF8 and the columns.
Thanks! Hope this helps someone.
Update: Grafana could solve this by adding the option I have described in this comment:
