I use Grafana 8.1.7
I tried to Download CSV from table data panel It has one column that contain data like “12305060789” this column is varchar in SQL table and In grafana I choose the Unit = string
but when open csv file in excel it show “12305060000” -
Can I config. that to be download corrected data?
What do you see if you open the csv using notepad++
