Not able to use variables inside the fields in JSON-api plugin.
reffered this link Variables | JSON API for Grafana.
Its not working for me.
Grafana 8
Grafana 8
Please give more details of what is not working for you.
Do you mean you cannot open the link in a browser (if so, what’s the error
message), or do you mean you run into some problem when following the
documentation (in which case, what exactly have you tried and what was the
result)?
Antony.
Link is perfectly working fine.
The syntax which is present in the link to use the variable in the panel is not working for me.
I have created a variable but not able to use in fields of panel.
