I am trying to get some json data using JSON API.
I configure in a variable obs_list to get 2 fields:
$.objetos[].id_objeto*
$.objetos[].nome*
But I cannot use these 2 fields in panel title or query.
I can only access the first field, using obs_list.
How can I get diferents fields variable in panel name and in query ?
