Grafana Cloud Version 9
I’m trying to add variables to a dashboard using an JSON feed → https://services.nvd.nist.gov/rest/json/cves/1.0?
I go to the dashboard that I want to add a variable too. I create the variable using the following param using SimpleJSON as my API.
Datasource = https://services.nvd.nist.gov/rest/json/cves/1.0?
Field = $.result.CVE_Items[*].cve.CVE_data_meta.ID
This returns a list of the data I want my dashboard to filter on.
I add this to the dashboard but when I select a particular CVE at random, it doesn’t get applied to any of the underlying tables. It’s almost like the variable is not dynamic.
As above.
I should be to filter on the data that I want only to show.
N/A
- Did you follow any online instructions? If so, what is the URL?
NA/
how are the underlying queries using this variable? can you please share?
I presume you mean this? See image.
As you can see, I’m just doing something very basic at the moment. I’m polling the data and looking to just view CVE-2022-32561. I’m yet to append any additional fields.
does not look like you are using the variable (from the drop down) anywhere in your A query. having a variable in of itself does not mean it will do something as far as I understand it. you have to use it in your queries
Hmmm there doesn’t appear to be any viable option to add this. Not at least using this Simple JSON api.
Thanks for the advice. I feel like what I’m trying to do isn’t possible with using the Simple JSON api. I’ll keep playing around and see if I can work it out.
hi louisleedavies,
would you use a variable in queries to filter data successfully?
I use JSONPath to query data: $.result.item[?(@.Name==“$variable”)].value
but I still got no data
Welcome
I would highly recommend using infinity plugin and also maybe try out jsonata query language
Can you please post sample json data you are trying to filter?
Glad to hear from you.
In this case, I want to display ‘SeismicIntensity’ in different regions by selecting different ‘StationName’.
Sample json data:
“records”: {
“Earthquake”: [
“EarthquakeNo”: 112033,
“Intensity”: {
“ShakingArea”: [
“EqStation”: [
“StationName”: “Hehuanshan”,
“SeismicIntensity”: “3”
“StationName”: “Shetou”,
“SeismicIntensity”: “4”
“EqStation”: [
“StationName”: “Taichaung”,
“SeismicIntensity”: “5”
“StationName”: “Tainan”,
“EarthquakeNo”: 112034,
“Intensity”: {
“ShakingArea”: [
“EqStation”: [
“StationName”: “Nantou”,
“StationName”: “Taidong”,
“SeismicIntensity”: “2”
“EqStation”: [
“StationName”: “Taipei”,
“StationName”: “Yilan”,
“SeismicIntensity”: “6”
Steps:
First, I create a variable(named as StationName) by using JSONPath:
$.records.Earthquake[].Intensity.ShakingArea[].EqStation[*].StationName
Then, I create a panel in dashboard and query the data by using JSONPath:
$.records.Earthquake[].Intensity.ShakingArea[].EqStation[?(@.StationName==“$StationName”)].SeismicIntensity
But It returns no data.
it only displays all data by using JSONPath:
$.records.Earthquake[].Intensity.ShakingArea[].EqStation[*].SeismicIntensity
please properly format the json blob of data you posted?
sorry, I format the data.
"records": {
"Earthquake": [
"EarthquakeNo": 112033,
"Intensity": {
"ShakingArea": [
"EqStation": [
"StationName": "Hehuanshan",
"SeismicIntensity": "3"
"StationName": "Shetou",
"SeismicIntensity": "4"
"EqStation": [
"StationName": "Taichaung",
"SeismicIntensity": "5"
"StationName": "Tainan",
"EarthquakeNo": 112034,
"Intensity": {
"ShakingArea": [
"EqStation": [
"StationName": "Nantou",
"StationName": "Taidong",
"SeismicIntensity": "2"
"EqStation": [
"StationName": "Taipei",
"StationName": "Yilan",
"SeismicIntensity": "6"
I solved it.
Really grateful to you for your help!!
