Hi
I have installed Grafana server on my laptop but not able to login and also on using of forget password it is showing sent mail to email id but not receiving any mail for reset password.
Please help.
Thanks
Gagan Deep
Hi
Please help.
Thanks
Gagan Deep
The email functionality like password reminders requires an email server to be configured - which is not done per default.
The default username is admin and the default password is admin. Grafana will prompt you to change it straight away.
If you changed the password and have forgotten it, then you can use the cli to reset it:
Thanks for your response !!!
