I do http:;/localhost, I get the web login of grafana, but the password is not correct (although I have it written down). Anyway I ask to reset the password, I enter my email, but I am not getting any new email with refresh instructions.
PLS help again
Thanks
Shai
For email you need to set the SMTP settings in grafana.ini
I don’t want email… I want to login. Grafana suggests to send me a new password in email.
What should I do in the ini file?..
Hi
Can you tell me where I can set up my password for grafana? I remember I defined a password, but don;t know where I can change it now…
Thanks,
Shai
Well, it is not a problem of the password. I changed my password.
When I run from http://localhost
It says “Problem! unauthorized”
Is this something I need to do with my port? the http 80 port?
(I see you have opened a separate question for this - I started answering your other question first).
Can you login with the default admin account (with password admin
yes, great works with Admin.
Daniel, what is the simplest way to use an excel data with grafana?.. (I understand I can not upload an excel table to grafana).
Can you explain your use case a bit more - why an excel sheet in Grafana instead of just using Excel charts?
