Customize Forgot Your Password email
    grafana version 11.2.2
    RHEL 9
    I’m trying to allow users to use the Forgot Your Password button to reset their own passwords.
    I setup the SMTP settings in grafana.ini and the emails are being received.
  • What happened?
    The link for “Reset Password” includes the PORT that grafana is being served on.
    Grafana is running behind a reverse proxy on a subpath and the PORT is not available at the border (I add the port in with the reverse proxy). This seems to be working well with most things in Grafana, so I assumed the port would not be included in the link in the email.
It would be nice if there was a way to customize this email or at least alter the pattern for the link so that the port is not present.
    I couldn’t find any relevant config to change.
    none received
    I couldn’t find any instructions for customizing the Forgot Your Password email.
