some of the dashboard are visible in the ui where some are present in grafana.db ,how can i find or load that dashboard and even grafana is not showing options to create new dashboard ,not able to find the settings button too. not able to view query in dashboard which are available , my version is 5.4.2
Hello, you can search for dashboards: https://grafana.com/docs/grafana/latest/dashboards/search/
Note: This may be a newer feature, and it may require an upgrade.
Related topics
| Topic | Replies | Views | Activity | |
| Created dashboards not visible on dashboard home page | 2 | 1827 | December 17, 2020 | |
Dashboard are missing without any change
0 | 310 | November 15, 2019 | |
| One Grafana dashboard suddenly missing | 0 | 247 | March 5, 2024 | |
| Unable to see saved dashboard | 2 | 1863 | January 12, 2022 | |
| I am not able to see the grafana usual dashboard like (settings, alertmanager, define variables) options. Please help how will i get that dasboard UI. I am login into grafana as admin | 3 | 424 | June 17, 2020 |
