I am not able to see the grafana usual dashboard like (settings, alertmanager, define variables) options. Please help how will i get that dasboard UI. I am login into grafana as admin
You are running a super old version of Grafana (multiple years), please use the offical download & install instructions
Thanks for the reply…shall i update the grafana version as i have already installed the setup?
Please refer to the upgrade instructions: https://grafana.com/docs/grafana/latest/installation/upgrading/
