while creating elasticsearch data source i i giving index [metricbeat-7.6.1-2020.04.17] it is working and able to access data but when i am giving [metricbeat-7.6.1-[YYYY.MM.DD] pattern daily] data source not created also no data able to see in grafana.
Hi @pritibhangale,
you do it the same as Index Patterns in Kibana (if you use Kibana).
Try metricbeat-7.6.1-* or even just metricbeat-*
Should work.
Hi bob,
metricbeat-* worked for me .
Thank you.
