Non text buildversion information as tooltip in timeseries graph
I am trying to plot a timeseries metrics graph with elasticsearch datasource. My document structure is like below
metric1: 21
metric2 : 33
buildVersion : T12345
while the metric values are numerical the build version is not. And it changes not frequently.
I wanted to show the buildversion as tootip everytime anyone hovers over the metrics in timeseries graph.
Is it a possibility and how ?
please post a sample es document
Thank you for your response, I dont have permission to share the document directly. But it looks like below
[#]duration : 32,545
[#] TPS : 12,5
[t] normalizedBuild : 4.0.1-19291
I am trying to plot TPS and want to show “normalizedBuild” information in the tooltip.
Thanks for your help
that does not look like a es doc json
post the structure and data obfuscated
Thank you for your reply. Here is the json
“_index”: “your_index_name”,
“_type”: “_doc”,
“_id”: “1”,
“_score”: 1,
“fields”: {
“duration”: [32545],
“TPS”: [12.5],
“normalizedBuild”: [“4.0.1-19291”]
curl -X POST “http://localhost:9200/your_index/_doc/” -H ‘Content-Type: application/json’ -d’
“TPS”: [12.5],
where is the datetime?
i posted the json from kibana and it is not showing datetime (though it exists)
hard to wrap my head around this json
	"_index": "your_index_name",
	"_type": "_doc",
	"_id": "1",
	"_score": 1,
	"fields": {
		"duration": [
			32545
		"TPS": [
			12.5
		"normalizedBuild": [
			"4.0.1-19291"
why are duration, tps and normalizedBuild arrays with single value?
