According to the Grafana documentation for node graphs (Node graph | Grafana Cloud documentation),
any field prefixed with
detail__will be shown in the header of the context menu when clicking on the edge. Useconfig.displayNamefor a more human-readable label
What I found is the option available under Standard options → Display name (Configure standard options | Grafana documentation) and using the expression ${__field.displayName}. However, this option is not available for node graphs.
Is it possible, then, for the information I want to display on the node to appear with thecolumn name instead of detail__column name ?
Notes:
- I am using the Infinity Data Source plugin to read CSV.
- Grafana Version: 11.1.3
- OS: Ubuntu 22.04.4 LTS
