In this node graph panel, the context menu appears with a world header, where is it from? According to the node graph doc and field detail__hello of csv data, i think the header should be hello.
versions:
grafana cloudgrafana v11.3.0
versions:
grafana cloudgrafana v11.3.0after you make changes, click the refresh button at the top right?
yes, i did
try changing it to something else instead of detail__hello
I think it’s a bit more complicated, and probably has to do with both infinity datasource and the nodegraph plugin.
this document on the official website may be outdated .
The following steps will basically meet my needs:
table format instead of node graph in infinity datasource.arc sections manually in the panel options, arc__*_color doesn’t work.I can confirm this here and seems to be a bug or broken in latest version of grafana. Can you create a issue in infinity repo with required details?
