This is my tooltip for the node graph, and in this, I want to change the tooltip names to my desired name for particular fields. Instead of this mentioned field for the tooltip, I want to rename it something else. How can I do this?
Hey @henilvaland
Yes it is possible to change tooltip name.
As per I understand you are doing this way →
Go to Query inspector, Click JSON and edit this way
“title”: “Panel Title”,
“transformations”: [
“id”: “renameByRegex”,
“options”: {
“regex”: “title”,
“renamePattern”: “Product Name”
“type”: “nodeGraph”
I hope this help for you.
Hey @shahnawazvhora7333 Thanks for responding.
Yes, it is helpful for me.
