No options displayed at Data source Settings except Delete and Back
Hello everyone,
your help is highly appreciated.
  • v12.3.0 /windows 10 pro
  • Configure a Data source for Microsoft SQL
  • Connections==> Datasources==> mssql
  • What happened?
  • At settings the only available options are Delete and Back.
  • I should see fields like Name, Host, Database, Authentication, and Additional settings on the MSSQL data source Settings page. [MSSQL configure]
  • I am on default configuration.
  • No errors
  • Yes consulted Grafana Grot allready and checked online documentation ( Configure the Microsoft SQL Server data source | Grafana documentation ). Has no relevant info for this.
Is the version… happened the same with the version V12.3.0 in windows 11 pro… changed it for the 10.0.0 version, and works for me, can edit the data sources.
Thank you very much.
The installation is based on windows 10 pro.
Tried with previous version 12.0.0 and configuration options are available now.
Is this a bug in latest version?
