Grafana V9.0 -
I wanna use MSSQL as data source and use the code builder as per grafana’s documentation
How are you trying to achieve it
I just simply add data source and I can connect to MSSQL data source successfully. -
What happened?
When I try the explorer option in grafana, I don’t have the option of “Code Builder”, only the “code mode” -
I should have the options to select either I will use code builder or code mode. -
No error’s as per logs. -
Microsoft SQL Server query editor | Grafana documentation
Thanks and Regards,
