No Data showing on Graph("Data Point outside time range") but in Query Inspector data is showing
Hi Team Grafana,
Tried to get the grafana graph with below mysql query and also FROM and TO time dynamic based on query, but graph is only populating current last 1 hour graph with response “Data Point outside time range” But in Query inspector data is showing, Pls help me get the correct graph, Thanks:
Query :
select UNIX_TIMESTAMP(pst.createdate) as time_sec, count(pst.pstpotrfnum) as value , count(pst.pstpotrfnum) as metric
from (select CONCAT(Air_Date,’ ‘,Slot_Start_Time) START_TIME,
DATE_ADD(CONCAT(Air_Date,’ ',Slot_end_Time), INTERVAL 15 MINUTE) as ENDTIME
from bi_projected_show_slot_master_discrete
where Air_Date="$SELECT_DATE" and Air_Partner="$SELECT_PLATFORM"
and Product_Id="$SELECT_PRODUCT" and ShowDuration="$SELECT_SHOW") as tview, octapil pil
inner join vendor_item_sku vis on pil.PILRFNUM = vis.pil_id
inner join vendor_item_sku_location visl on visl.vendor_item_sku_id=vis.id
inner join octapst pst on pst.vendor_item_sku_location_id=visl.id
where pil.PILPBIRFNUM="$SELECT_PRODUCT"
and pst.CREATEDATE >= tview.START_TIME
and pst.CREATEDATE <= tview.ENDTIME group by pst.pstpotrfnum
Query Inspector :
“xhrStatus”: “complete”,
“request”: {
“method”: “POST”,
“url”: “api/tsdb/query”,
“data”: {
“from”: “1520101800000”,
“to”: “1520706599999”,
“queries”: [
“refId”: “A”,
“intervalMs”: 900000,
“maxDataPoints”: 720,
“datasourceId”: 1,
“rawSql”: “select UNIX_TIMESTAMP(pst.createdate) as time_sec, count(pst.pstpotrfnum) as value , count(pst.pstpotrfnum) as metric\n from (select CONCAT(Air_Date,’ ‘,Slot_Start_Time) START_TIME,\n DATE_ADD(CONCAT(Air_Date,’ ',Slot_end_Time), INTERVAL 15 MINUTE) as ENDTIME\n from bi_projected_show_slot_master_discrete\n where Air_Date=“2018-03-06” and Air_Partner=“Ezmall.com”\n and Product_Id=“1087” and ShowDuration=“09:15 - 09:30”) as tview, octapil pil\n inner join vendor_item_sku vis on pil.PILRFNUM = vis.pil_id\n inner join vendor_item_sku_location visl on visl.vendor_item_sku_id=vis.id\n inner join octapst pst on pst.vendor_item_sku_location_id=visl.id\n where pil.PILPBIRFNUM=“1087”\n and pst.CREATEDATE >= tview.START_TIME\n and pst.CREATEDATE <= tview.ENDTIME group by pst.pstpotrfnum”,
“format”: “time_series”
“response”: {
“results”: {
“A”: {
“refId”: “A”,
“meta”: {
“rowCount”: 6,
“sql”: “select UNIX_TIMESTAMP(pst.createdate) as time_sec, count(pst.pstpotrfnum) as value , count(pst.pstpotrfnum) as metric\n from (select CONCAT(Air_Date,’ ‘,Slot_Start_Time) START_TIME,\n DATE_ADD(CONCAT(Air_Date,’ ',Slot_end_Time), INTERVAL 15 MINUTE) as ENDTIME\n from bi_projected_show_slot_master_discrete\n where Air_Date=“2018-03-06” and Air_Partner=“Ezmall.com”\n and Product_Id=“1087” and ShowDuration=“09:15 - 09:30”) as tview, octapil pil\n inner join vendor_item_sku vis on pil.PILRFNUM = vis.pil_id\n inner join vendor_item_sku_location visl on visl.vendor_item_sku_id=vis.id\n inner join octapst pst on pst.vendor_item_sku_location_id=visl.id\n where pil.PILPBIRFNUM=“1087”\n and pst.CREATEDATE >= tview.START_TIME\n and pst.CREATEDATE <= tview.ENDTIME group by pst.pstpotrfnum”
“series”: [
“name”: “1”,
“points”: [
1,
1520308593000
1,
1520308812000
1,
1520309075000
1,
1520309093000
1,
1520309206000
1,
1520309430000
“tables”: null
How to override date from grafana Datetime to Variable.
You want to use the $__timeFilter macro function to filter by timerange selected in Grafana. See documentation.
Marcus
I’m having similar issue like grafana dashboard is displaying ‘NO DATA’ for some metrics. I have around 2k VMs in my estate but it isn’t loading a few metrics. Can anyone assist to fix that?
Hi. Let me know if you can assist for my query as well
Thank you
