Hey,
I am using Grafana Version 4.5 with MYSQL as datasource. But while quering , i am not able see any changes in the time mode as well as series mode in the graph.
Suppose I have data for 2017 also, but while setting time range for last 1 year or last 2 year, it says Data points outside range when running MYSQL query. It only works for last 5 year. So filtering is not there.
And zoom out is not working in the series mode.
Query-
SELECT
ts as time_sec,
revenue as value,
ds as metric
FROM ****
where ts is not null and revenue > 50 and ds > "2017-05-19"
group by ds, ts
order by ds asc
limit 100000;
you need to use the included $__timeFilter(column) macro, http://docs.grafana.org/features/datasources/mysql/#macros
Hey ,thanks . This is working with the table with 10-digit timestamp but not with 13 digit timestamp. so can you please help in that?
That is not supported right now
no, time range filtering is required.
Thanks for quick reply
I have epoch time in 13 digits so its not supporting .
So is there any alternate solution .
