Data points outside range to be disabled
Hi Guys,
Can i resolved this one by using time_filter? this is the query that i used on this dashboard.
Select time, total_request, rc2001,rc3002,rc3004,rc4010,rc4012,rc5002,rc5012,rc5030,rc5031,rc6000 from PROD_ERROR_CODES;
or Select * PROD_ERROR_CODES;
Please advise.
    5.4.3
    to get of rid the datapoints outside range
  • What happened?
Yes, you can.
You didn’t mention what data source you’re using. It looks like Influx, in which case a simple WHERE $timeFilter clause will do it for you (Add and manage variables | Grafana documentation)
Thank you for your reply!
I’m using PostgreSQL. how can i apply that time filter on the query?
PostgreSQL | Grafana Labs : WHERE $__timeFilter(time)
Thank you svetb :smiley:
It worked!
