Please does anyone know if it is possible, after downloading RabbitMQ-Overview dashboard on Grafana, connect it to any RabbitMQ running in a cluster. Because There is no data available on the dashboard although I have a RabbitMQ server running fine.
It looks like it requires the Prometheus data source and RabbitMQ needs to be configured first to send Prometheus metrics and there’s a Prometheus plugin for RabbitMQ you need to enable: Monitoring with Prometheus & Grafana — RabbitMQ
Once that’s done, the Grafana side - check out the docs for the Prometheus data source: Prometheus | Grafana Labs
I am using kube-prometheus-stack helm chart which uses exporters to send metrics to prometheus. I have already setup a rabbitmq exporter and metrics are being sent to prometheus and are visible on grafana.
In addition, I made sure the rabbitmq_prometheus plugin is enabled as it was required for the RabbitMQ-Overview dashboard on Grafana Labs
Requires rabbitmq-prometheus to be enabled, a built-in plugin since [RabbitMQ v3.8.0]
:/$ rabbitmq-plugins list
Listing plugins with pattern ".*" ...
Configured: E = explicitly enabled; e = implicitly enabled
| Status: * = running on rabbit@rabbitmq-0.broker-server
[E*] rabbitmq_management 3.8.9
[e*] rabbitmq_management_agent 3.8.9
[ ] rabbitmq_mqtt 3.8.9
[e*] rabbitmq_peer_discovery_common 3.8.9
[E*] rabbitmq_peer_discovery_k8s 3.8.9
[E*] rabbitmq_prometheus 3.8.9
But still there is no data shown on RabbitMQ-Overview dashboard, my only work-around approach to solve my issue is to copy the JSON Model of the RabbitMQ-Overview to my current RabbitMQ dashboard on Grafana.
I will check the docs for Prometheus data that you have sent. Thank you
Hey @anon80964540, my apologies but I have been stuck on this issue for 3 days trying to work out the problem and I still don’t know what is the problem.
On my grafana service I have the prometheus datasource.
I have enabled all plugins for my rabbitmq such as rabbitmq_prometheus, rabbitmq_top, rabbitmq_tracing and rabbitmq_event_exchange.
I made sure the RabbitMQ-Overview dashboard is using the same datasource for all my grafana dashboards.
Can you please tell me if there is a way I can debug this issue for my grafana dashboard.
Hi, I’ve the same issue. Prometheus is working.
I noticed that RabbitMQ-Overview queries definition uses some metrics that I cannot find in the metrics list (See the attached screenshot). They all start with “rabbitmq_” suffix, but I can’t find any metric of that type.
I also attach a screenshot of my RabbitMQ’s plugin list.
