Grafana version 8.1.5
SQLite plugin version 2.1.0 (frser-sqlite-datasource)
MacOS Big Sur 11.5.1 -
Creating a simple line chart by fetching time and value from a SQLite DB -
I created a new panel and use this query to fetch data
WITH converted AS (
SELECT future_oi_abs, date || ‘T00:00:00Z’ AS datetime FROM fao_mkt_summary where symbol = “$symbol”
SELECT datetime, future_oi_abs FROM converted ORDER BY datetime ASC
What happened?
The query shows - no data in response. Inspector shows the right query but no data
Same query, run directly on SQLite DB returns results.
The DB exists and Grafana connects to it fine. The variable $symbol that currently has value ACC has been extracted from the very same DB.
Can someone please point me to what am I missing? Why would query run fine directly on DB but fail via Grafana.
