I am new to Grafana/InfluxDB. I just installed them as part of IOTstack with Docker.
I am feeding data from Node Red to InfluxDB (ok), but I cannot connect from Grafana to InfluxDB to show them. You can see my settings in the attached pic.
Message: Cannot read properties of undefined (reading ‘data’)
Regardless of whether “basic out” is checked, I get the same results
Also there is no text entry field for the database token for InfluxDB.
Grafana v6.3.6(fdd2117)
Any help would be appreciated!
P.
Which version of InfluxDB are you using?
InfluxDB v2.7.11
Server: fbf5d4a
Frontend: f4b5694
The above is a very old version. Can you update to the latest?
What puzzles me, that as stated above, these 2 (Grafana/InfluxDB) came as part of an install script used by many from around IOT. I will update all packages to the newest, thank you!
Can you link to this script? Maybe the folks at Grafana can reach out to them and have it corrected.
Grafana 6.3.6 was released on 2019-09-23, I am not sure that is compatible with InfluxDB 2.x which was only at alpha stage in that period.
Either try updating Grafana to the latest one, or try to use InfluxDB 1.x if you really need to keep that old version of Grafana.
This is the script:
