I have installed Grafana as a Plugin inside Home Assistant, as well, as I installed influxdb. A little Dashbourd showed me the yield of my solar collectors.
Since a viewe weeks Grafana shows no data anymore. But if I start my browser in private mode and log on to home assistant, Grafana works correct.
Any Idea?
Teddytimo
Hello @teddytimo,
It seems the issue may be browser-related rather than with Grafana or InfluxDB. I recommend clearing your browser’s cache and cookies, which may resolve the problem.
You can also configure your browser to automatically clear cache and cookies after a set period to help prevent similar issues.
Thanks
Hello @teddytimo
Just checking in—did this solution resolve your issue, or are you still experiencing the same problem?
