Newly Installed Grafana under Docker User and Password
Latest grafana-enterprise
    Start Graphana operation
    By entering user name and password at Welcome to Grafana screen
  • What happened?
    Login Failed. Invalid username or password
    Normal program operation
    No
    See below.
I am attempting to install Graphana on my Azure VM running Ubuntu 22.04 and Docker 26.0.0. via a command line interface. I found instructions at link [Run Grafana Docker image | Grafana documentation] - specifically I used the CLI command
sudo docker run -d -p 3000:3000 --name=grafana grafana/grafana-enterprise
This command seemed to work well, producing screen output of various Pull complete and ending with
Status: Downloaded newer image for grafana/grafana-enterprise:latest
e0e659bd526d95628d5f01252aa5897d62f80bf5d93aa25f48bf706635e3fc02
I next used my browser to connect to port 3000 of my/Azure VM. I see the “Welcome to Grafana” screen with Email or User Name and Password to be entered. I previously ran a older version of Grafana/oss. The previous user and password are not accepted by the new Grafana. I am out of guesses.
What user name and password do I use?
Try the default
admin
admin
Hi yosiasz
Yep, that worked. I think I entered admin, admin rather than the capitalized versions. Anyway, I’m in!! I bet that is in documents somewhere…
Now I find myself puzzled by the lower-case versions specified at
Antony.
Got bitten by auto capitalize on my phone :rage:
