New canvas panel not avaiable in v9.0.3
Hi I want to test the new Canvas panel & in particular the feature in the vid below.
I’m testing using my account on grafana.net the panel isn’t listed but does appear in search stating it’s included. Does this have to be enabled in settings?
Canvas panel - Native Plugin
The Canvas Panel is included with Grafana.
// vid
Thanks
Hi @iilaw welcome to the :grafana: community
This panel is basically alpha based i.e. still room for improvement.
You can use this plugin by enabling the line;
enable_alpha = true
As described in;
Let me know if this helps.
Many thanks for taking the time to replay.
I run hosted Grafana so will have to wait for the beta as I can’t modify settings.
