Grafana v.7.1.3
Objective: I want to use the Button Control Panel plugin to be able to do database actions on click.
Executed action
- Downloaded plugin zip
- Installed it in the folder defined in the .ini file
- Restarted Grafana
- Looked into plugin list
- Added a new panel to a dashboard
- Tried to change panel type to button
Expected behavior
3. Plugin is loaded (log line)
4. Plugin appears in plugin list
5. New panel appears
6. All panel types appear including new plugin button
Observed behavior
1 to 5: as expected
5: The Button pluging is classified as plugin and signed
6: Only standard panel types appear. When filtering to button, lists gets empty
Online instructions followed
https://grafana.com/grafana/plugins/speakyourcode-button-panel/?tab=installation
