See image below. it seams like there is a limit for how much data the network will log and then resets. is it possible to make the graph continue without having the dips.
I see that you are using an influxdb data source, the dips are coming from your data and not from grafana.
Correct me if I’m wrong.
Good Luck
Yes, that’s true. So then I need to fix that in influxdb I guess. I was hoping that there were some functions in grafana that could help me with that, instead of “fixing” the source.
