I´m using an ASP.NET as a data source to Grafana, but every time I try to connect to it, I get the error “Failed to fetch:net::ERR_CERT_AUTHORITY_INVALID.” I´ve tried to connect to the same endpoint using postman, and I got no problems.
I´ve tried on both Chrome and EDGE browsers, but the issue persists.
1 - I developed a method in ASP.NET that return the code 200 for that endpoint
2 - I tested it using postman and the endpoint worked returning the wanted code 200
3 - I configured the Data Source in the locally installed grafana and tested the connection, giving me a fail to fetch error
“Failed to fetch:net::ERR_CERT_AUTHORITY_INVALID.” is the message when hovering the “failed”
Resuming, I can connect to the API from postman without problems, but when I try to connect from my locally installed grafana to my locally running API it retrieves the above-mentioned error. What can I do to make it work ?
I´ve already tried in the Microsoft EDGE browser too
