Hi all,
I’m using Grafana 9.2.2 to try and add a basic trend line for some temperature data.
So far I have a standard time series panel that pulls in the temperature data, and then another time series panel (at the moment) that references the first, but then applies a ‘StdDev’ transformation.
This is showing me the change in results in positive values. Is there a way to show a negative change in a negative result?
