Method -1: I have tried to use GEOMAP plugin for the same but graph is not remained static and can’t apply different color coding based on different time zone.
Method -2:Tried to use Text Panel and using HTML am able to integrate static graph but then I want to mark location on the map using longitude and latitude which is not happening, source of this longitude and latitude is dynamic JSON data.
Basically , I need to dynamic mark location based on JSON on the static geographical map and apply different color on based on timestamp.
NOTE:- Input JSON data has longitude, latitude,city and timezone .please help/suggest how to solve in this case.
