v9.2.4 -
Y axis is in my panel is coming from duration in d hh:mm:ss unit. The values are absolute, which is perfect, but the markers look ugly on the axis. Can I change it in someway to display the y axis markers more rounded up and clean keeping the actual data to be absolute. -
Unit filter in the panel edit. It has only few options for duration:
- duration(s)
- duration(hh:mm:ss)
- duration (d hh:mm:ss)
but none of these is helping me get the best visualization
- What happened?
it either displays:
- Duration(s) fixes the y axis markers as human readable compact ones, but the data points are highly rounded off. for 1h 28 min, it displays only 1 hr for my data point.
- duration (hh:mm:ss) fixes my data point, but the y axis marker looks complex and crammed.
- duration(d hh:mm:ss) fixes my data point, but the y axis marker looks complex and crammed.
duration(s) should not round up the data point so vaguely. -
