Need helping / tips / advice in drawing line/scatter graphs, year by year lines
I am very new to Grafana. Using v9.3 on Mac and my data in MySQL.
I had all my data in one massive raw table, with date/time and value column, I used SQL and procedures to turn that table in pivot like table, see attached (i turned to pivot table, i read somewhere Grafana like data in that style).
graph
I have trying for past day(s) to draw line or scatter graph, each year separate colour line (all in one single graph).
Please help.
After starting the post, this is the best, I have got so far, I would like something like this all one one chart, Y axis is fine, X axis to to be Jan, Feb… Dec, Line or scatter each for year, to say 2022 (red), 2021 (green), 2020 (blue) … etc.
SQL for Grafana chart:
select * from full_p_data;
SQL for table above DDL/DML
CREATE TABLE `full_p_data` (
  `YEAR` varchar(4) DEFAULT NULL,
  `Jan` decimal(42,0) DEFAULT NULL,
  `Feb` decimal(42,0) DEFAULT NULL,
  `Mar` decimal(42,0) DEFAULT NULL,
  `Apr` decimal(42,0) DEFAULT NULL,
  `May` decimal(42,0) DEFAULT NULL,
  `Jun` decimal(42,0) DEFAULT NULL,
  `Jul` decimal(42,0) DEFAULT NULL,
  `Aug` decimal(42,0) DEFAULT NULL,
  `Sep` decimal(42,0) DEFAULT NULL,
  `Oct` decimal(42,0) DEFAULT NULL,
  `Nov` decimal(42,0) DEFAULT NULL,
  `Dec` decimal(42,0) DEFAULT NULL
-- Data for table
INSERT INTO `full_p_data` VALUES ('2015',NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,5,11,19,6),('2016',17,26,17,10,21,13,10,18,19,15,12,10),('2017',20,18,23,19,20,16,11,9,10,12,14,8),('2018',20,17,17,6,18,21,11,10,14,9,9,5),('2019',20,16,37,30,25,12,11,8,8,5,5,10),('2020',9,2,6,16,4,6,17,11,15,7,9,26),('2021',16,18,16,9,5,10,6,4,8,6,16,5),('2022',11,8,6,5,19,10,20,9,17,8,22,3);
Thank You very much any help.
Info:
    9.3
    Draw scatter or line graph (year by year lines), X axis have Month, X axis have the numbers qty, each line on graph be different colour.
    SQL
  • What happened?
    Only 1 line, by i want line for each year
    8 lines
Welcome
Could you please provide dml and ddl for your data? It helps us help you because we can have your data in our mysql. Hard to do that from an image
:wink:
Thank You very much for getting back. I have edited my original post to include code to test. My original data was like this below, before I turned my data into pivot table like data (for Grafana purpose). Now sure, if my raw data makes it easy for the graph.
CREATE TABLE `full_sales_log` (
  `MONTH` varchar(2) DEFAULT NULL,
  `c_val` bigint(21) NOT NULL
INSERT INTO `full_sales_log` VALUES ('2015','09',5),('2015','10',11),('2015','11',19),('2015','12',6),('2016','01',17),('2016','02',26),('2016','03',17),('2016','04',10),('2016','05',21),('2016','06',13),('2016','07',10),('2016','08',18),('2016','09',19),('2016','10',15),('2016','11',12),('2016','12',10),('2017','01',20),('2017','02',18),('2017','03',23),('2017','04',19),('2017','05',20),('2017','06',16),('2017','07',11),('2017','08',9),('2017','09',10),('2017','10',12),('2017','11',14),('2017','12',8),('2018','01',20),('2018','02',17),('2018','03',17),('2018','04',6),('2018','05',18),('2018','06',21),('2018','07',11),('2018','08',10),('2018','09',14),('2018','10',9),('2018','11',9),('2018','12',5),('2019','01',20),('2019','02',16),('2019','03',37),('2019','04',30),('2019','05',25),('2019','06',12),('2019','07',11),('2019','08',8),('2019','09',8),('2019','10',5),('2019','11',5),('2019','12',10),('2020','01',9),('2020','02',2),('2020','03',6),('2020','04',16),('2020','05',4),('2020','06',6),('2020','07',17),('2020','08',11),('2020','09',15),('2020','10',7),('2020','11',9),('2020','12',26),('2021','01',16),('2021','02',18),('2021','03',16),('2021','04',9),('2021','05',5),('2021','06',10),('2021','07',6),('2021','08',4),('2021','09',8),('2021','10',6),('2021','11',16),('2021','12',5),('2022','01',11),('2022','02',8),('2022','03',6),('2022','04',5),('2022','05',19),('2022','06',10),('2022','07',20),('2022','08',9),('2022','09',17),('2022','10',8),('2022','11',22),('2022','12',3);
