Need help with setting up SMTP in Grafana ECS, as we are unable to find grafana.ini
  • What happened?
I guess your “ECS” is AWS ECS: the simplest solution is to use env variables on the ECS task level
How do we achieve this.
I have one more doubt - regarding monitoring snowflake using Grafana Community
